Macworld
macworld.com › home › macos
What macOS can my Mac run? macOS 27 Compatibility Checker | Macworld
1 week ago - Latest version: macOS Ventura 13.7.8, August 20, 2025. MacBook models from 2017 or later · MacBook Air models from 2018 or later · MacBook Pro models from 2017 or later · Mac mini models from 2018 or later · iMac models from 2017 or later ...
MacSales.com
eshop.macsales.com › home › support › mac os compatibility guide
Mac OS Compatibility Guide by Mac Model
Which versions of macOS does your Mac Studio, Mac Pro, iMac, iMac Pro, or Mac mini support? ... Sign up for our mailing list and receive special offers created just for OWC subscribers. Sign up here · iMac, Mac, MacBook, MacBook Air, MacBook Pro, Mac Pro, OS X, Retina, and Xserve are trademarks of Apple Inc., registered in the U.S.
How Can I Update My MacOS? (MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports))
r/OpenCoreLegacyPatcher if you want to go past Ventura Should be able to download Ventura from here and install natively: https://mrmacintosh.com/macos-ventura-13-full-installer-database-download-directly-from-apple/ More on reddit.com
🌐 r/MacOS
19
0
September 24, 2025
Which OS is best for a 2017 MacBook Pro in terms of performance and reliability?
Currently running macOS 11.7.7 on my 2017 MacBook Pro Dual-Core Intel Core i7 3.5 GHz · I know newer OSs have various bells and whistles. But I believe they are mainly geared to newer processors More on discussions.apple.com
🌐 discussions.apple.com
December 30, 2023
best OS for macbook pro 2017?
You might also try setting up your new iPhone as new, instead of restoring a backup from a much older phone. It will let you experience all the new features and upgrades from the beginning, and it might save you a few headaches down the road that are related to old leftover settings. You also won't need iTunes/Finder in this case More on reddit.com
🌐 r/MacOS
21
9
December 9, 2021
Latest macOS upgrade available for my MacBook.
Monterey not upgrading to Sonoma My macbook pro from 2016 (with 15 inch display and 16 gb of RAM), running macOS 12.7.5, isn't upgrading to Sonoma. Please help me. 607 1 · Can I download MacOS Ventura or Sonoma on my MacBook Air 2017? I have my MacBook updated to Monterey but was wondering if I could get any newer software updates on it? Thanks so much and God Bless! 704 3 · I have a MacBook 13, using Venture OS... More on discussions.apple.com
April 5, 2024
People also ask
Is my MacBook compatible with macOS Sonoma?
If your MacBook model is from 2018 or later, it's likely compatible with macOS Sonoma (14). Apple's official list includes MacBook Air (2018+), MacBook Pro (2018+), and other recent Macs. To confirm, check "About This Mac" and compare your model to Apple's Sonoma compatibility list.
setapp.com
setapp.com › how-to › macos-compatibility-guide
macOS compatibility guide: What OS can my Mac run?
Which Macs have macOS Sequoia compatibility?
macOS Sequoia (15) supports a range of recent Macs, including Apple silicon models and many newer Intel Macs: MacBook Air (2020 and later), MacBook Pro (2018 and later), iMac (2019 and later), iMac Pro (2017), Mac mini (2018 and later), Mac Studio (2022 and later), Mac Pro (2019 and later).
setapp.com
What happens if my Mac is not compatible with the latest macOS?
If your Mac isn't officially supported by the latest macOS, you won't see that update in Software Update, and you can't install it normally. You can continue using your current version, but you'll miss new features and eventually stop receiving security updates for older macOS versions.
setapp.com
EveryMac.com
everymac.com › systems › by_capability › maximum-macos-supported-by-all-apple-silicon-macs.html
Maximum Supported macOS for Apple Silicon Macs: EveryMac.com
3 weeks ago - The maximum version of macOS supported by each Apple Silicon Mac (2020-Current) is listed below. This list includes Apple Silicon Macs from the MacBook Neo, MacBook Air, MacBook Pro, iMac, Mac mini, Mac Studio, and Mac Pro lines.
reddit.com › r/macos › how can i update my macos? (macbook pro (13-inch, 2017, two thunderbolt 3 ports))
r/MacOS on Reddit: How Can I Update My MacOS? (MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports))
September 24, 2025 -
Dumb question probably but here are my specs of what kind of MacBook I have and the current MacOS it's running on.
MacOS High Sierra
Version: 10.13.6
Processor 2.3 GHz Intel Core i5
Is it possible for me to update it further than Version 10.13.6?
Each time I click "Software Update" on the About This Mac overview screen, it will take me to the app store. But there will be no update available. I added a picture below...
Please let me know what I can do or if my macbook is too old to be updated any further.
Setapp
July 9, 2026 - ✓ Sonoma 14 — all Apple Silicon + Intel Macs from 2017–2018 onwards. ✓ Monterey 12 or earlier — Intel Macs from 2014–2016; no newer version available. The latest macOS is Tahoe 26 (September 2025): It requires Apple Silicon or specific ...
Mac of All Trades
macofalltrades.com › home › macos compatibility
macOS Compatibility Guide
MacBook: Early 2015 to 2017 · MacBook: Late 2008 to 2010 · MacBook Air: Late 2008 to Early 2015 · MacBook Pro: Mid/Late 2007 to Early 2015 · Mac mini: Early 2009 to 2014 · iMac: Mid 2007 to Mid 2015 · Mac Pro: 2008, 2010, 2013 · Compatible with OS X 10.10 Yosemite (Released in October ...
Mac Cheat Sheet
yama-mac.com › en › macos_correspondence_table
Mac model OS compatibility table | Mac Cheat Sheet
October 4, 2024 - A list of compatible macOS (OS X) versions is posted for each Mac model.The OS cannot be installed or booted for the unsupported version.
Anythingmac
anythingmac.net › home › posts › is your 2015 to 2020 macbook pro or imacready the latest & fastest macos upgrade?
Mac OS Upgrade compatibility Chart for MacBook Pro or iMac
July 25, 2024 - For example: If you Mac is a 13 inch 2018 MacBook Pro, you probably would want to stay in Mac OS Ventura, since that is the last stable version of the previous operating system.
Apple Community
discussions.apple.com › thread › 254892130
December 30, 2023 - Currently running macOS 11.7.7 on my 2017 MacBook Pro Dual-Core Intel Core i7 3.5 GHz.
Apple
support.apple.com › en-bw › docs › mac
Mac Manuals and Downloads - Apple Support (BW)
MacBook Pro (13-inch, 2018, Four ... Four Thunderbolt 3 Ports) MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports) MacBook Pro (15-inch, 2017) macOS High Sierra ·...
Apple
support.apple.com › en-bw › 108052
Identify your MacBook Pro model - Apple Support (BW)
3 weeks ago - The easiest way to find the name ... number, even when you don’t have your Mac or it doesn’t start up all the way. This model has the M5 Pro or M5 Max chip and includes three Thunderbolt 5 ports....
reddit.com › r/macos › best os for macbook pro 2017?
r/MacOS on Reddit: best OS for macbook pro 2017?
December 9, 2021 -
kinda complicated but after mojave i stopped upgrading the OS bc i was afraid my computer would slow down. so now i’m like 4 OSs behind. i do the same thing on my iphone and my 6s is still running ios 12 lol. my mom just sent me her old iphone 11 and in order to restore from my itunes backup and connect to the new phone i would need to upgrade my OS. does anyone know what the minimum OS is to connect to the iphone 11, or if i can just upgrade to the latest OS without slowing down my machine? if possible i would upgrade to monterey but i don’t know if my computer can handle it.
thank you!!!!
Apple Support
support.apple.com › en-us › 111951
MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports) - Technical Specifications - Apple Support
Testing conducted by Apple in May 2017 using preproduction 2.3GHz dual-core Intel Core i5-based 13-inch MacBook Pro systems with 8GB of RAM and 1TB SSD.
Apple Community
discussions.apple.com › thread › 255561665
April 5, 2024 - A 2017 MacBook Pro can be upgraded to the current version of Ventura macOS 13.
Dortania
dortania.github.io › OpenCore-Legacy-Patcher › MODELS.html
Supported Models | OpenCore Legacy Patcher
2 weeks ago - Any Intel-based Mac listed below can install and make use of OpenCore Legacy Patcher. To check your hardware model, open System Information and look for the Model Identifier key · It is extremely recommended to update your Mac to its latest native version before using OpenCore Legacy Patcher, ...
Apple Community
discussions.apple.com › thread › 255199260
Is MacBook Pro(2017) compatible to macOS … - Apple Community
October 12, 2023 - You need a newer Mac that supports Sonoma. ... For the record, I too have a 2017 MBP, and of course I’m disappointed that my own “Top of the Line Hardware as-of July 2017” didn’t make the cut. That said, it was absolutely no “surprise” … · … Apple publishes hardware compatibility lists as each “new OS” is formally announced (several months prior to the actual software rollout).
Low End Mac
lowendmac.com › home › 13″ macbook pro (mid-2017)
13" MacBook Pro (Mid-2017) - Low End MacLow End Mac
December 5, 2024 - Although it is not officially supported, the 13? 2017 MacBook Pro can run the latest intel build of macOS via OCLP. This MacBook Pro has an Intel Iris Plus GPU which is compatible in later versions of macOS.
reddit.com › r/macos › macos for macbook air 2017
r/MacOS on Reddit: MacOs for Macbook Air 2017
August 16, 2023 -
Hi everyone, i want to install a fresh copy of mac os on my macbook air 2017 model. Which mac os should be the best to be installed on this macbook. It is compatible with mac os Ventura, mac os Monterey, mac os Big Sur and mac os Catalina. Which one of these is the best macos for my macbook air 2017 ? Kindly help
reddit.com › r/macos › it’s wild to think that if you bought a macbook pro in 2017, it’s no longer supported.
r/MacOS on Reddit: It’s wild to think that if you bought a MacBook Pro in 2017, it’s no longer supported.
September 19, 2023 -
I made a habit out of maxing my MacBooks in the past. It’s been worth it since I’ve needed it for work and use them for everything.
Saying that, I’m really not seeing the incentive to do that much anymore. The mid loadout for the M-series MacBooks seem good enough. Not to mention, I’ve read a few studies now that suggest Apple is trying to trim down the MacBook lifecycle even further.
It seems crazy to me that my 2013 MacBook Pro has almost as much power as my current Intel-based 2019 MacBook Pro (on paper and in practice), but it hasn’t been supported for years. I’m sure there are good reasons, but I still use that thing as my second workbook because of how fast it is to this day.
As a software dev, I know it’s not really logical to expect them to maintain this stuff forever. I’ve accepted that my 2013 MacBook Pro has already been unable to install the newest apps for a few years now due to OS requirements. Still, it just seems crazy to think that a MacBook purchased today might be deprecated in 5 years time.
Edit: Clarify 2019 MacBook Pro (Intel-based).
My bigger issue is concerning the developer tools, which I didnt do a great job at getting across. Regardless of how powerful my MacBook is, if it doesn’t run the latest macOS, I’m forced to purchase a new MacBook. So even though my MacBook Pro is fully maxed out, capable of running the newest OS and exponentially more powerful than other MacBooks from that year, I have to buy a new MacBook anyway just because they get phased out by year-of-manufacturing instead of by hardware capability. Thus, I feel no reason to invest in a high end MacBook anymore.
