DC Rainmaker
dcrainmaker.com › 2025 › 04 › wahoo-trackr-radar-cycling-details.html
Wahoo TRACKR RADAR Hands-On: All The Details | DC Rainmaker
September 19, 2025 - ... I know it’s a bummer about mount. Though if you really like this radar you can modify your garmin mount to wahoo mount. Just make one “ear” a bit wider on garmin mount, and then wahoo should fit right in.
Wahoo Fitness
support.wahoofitness.com › hc › en-us › articles › 26346188903442-Mount-TRACKR-RADAR-to-a-bicycle
Mount TRACKR RADAR to a bicycle – Wahoo Fitness Support
TRACKR RADAR is not compatible with radar mounts made for Garmin radar units, unless the mount offers a replaceable Wahoo-compatible puck.
Trackr on saddle mount
This is how I have my Varia mounted, the best spot IMO, clean, well placed for its optimal function. More on reddit.com
🌐 r/wahoofitness
30
23
May 21, 2025
Garmin Edge on Wahoo mount
You can check out thestickybottle on IG. They make custom mounts, links, extenders etc for bike computers & lights. Aaron can recommend you something. More on reddit.com
🌐 r/cycling
23
9
September 3, 2021
Getting creative with a Garmin Varia mount (pannier rack) & up front Wahoo mount?
Deal with the up front first as I think that'll be easiest. Wife not a confident cyclist. First time out in a long time for her today & she wanted to try out the Varia to see if it helped with her confidence. Issue was, my Wahoo wouldn't clamp on to her handlebar. The mount was supplied with 2... More on cyclechat.net
🌐 cyclechat.net
13
September 3, 2022
Switching from garmin mount to wahoo mount ?
I’ll swap you if you still have this mount! I have the same problem, but in reverse. Garmin edge 530, this exact same amount, but for wahoo. More on reddit.com
🌐 r/CanyonBikes
7
2
June 23, 2024
Bikerumor
bikerumor.com › home › kom’s saddle rail radar mount plays nice with garmin & wahoo
KOM's Saddle Rail Radar Mount Plays Nice with Garmin & Wahoo - Bikerumor
April 23, 2026 - KOM says the mount is designed to work with both Garmin and Wahoo radar units, which make up most of the radar world. Accessory ecosystems still love making small things annoyingly brand-specific, and radar mounts are no exception.
The Sweet Cyclists
thesweetcyclists.com › home › the streamlined radar mount option
KOM Cycling Saddle Rail Bike Rear Radar Mount Garmin Wahoo
May 8, 2026 - Aside from the small red KOM Cycling logo on top and the yellow colored Wahoo adapter, the mount has an all black finish. KOM Cycling includes both a black Garmin adapter as well as a blue Wahoo adapter to make the mount compatible with different radars on the market.
reddit.com › r/wahoofitness › trackr on saddle mount
r/wahoofitness on Reddit: Trackr on saddle mount
May 21, 2025 -
V lucky to be gifted a Wahoo Trackr Radar. I used a Garmin radar with a 3D printed SWAT mount. Have been reading around about the tweaked mount etc which worried me. But bought a Wahoo insert and stuck it in my mount and it looks smart. Set up and integration with Roam 3 (another gift) was simple. Out on the road with it later this week.
CYCLITE
cyclite.cc › en › products › radar-mount-02
RADAR MOUNT / 02 – Secure radar light on your saddle bag | CYCLITE
RADAR MOUNT / 02
RADAR MOUNT / 02 is the solution for mounting a radar tail light (Garmin / Wahoo / Sigma) on saddle bags. Especially on long rides with traffic, more and more bikepackers appreciate the added safety of radar. Since the seatpost position is occupied by the bag, a stable, function-specific mount on the saddle bag was missing until now. This 18 g part is fixed with an O‑ring to all CYCLITE saddle bags (and to saddle bags from other brands with vertical slots). Using the standard quarter-turn interface, the radar device can be attached and removed quickly and easily. Recently, the RADAR MOUNT / 02
Price   €29.90
Cycling Weekly
cyclingweekly.com › reviews › bike lights and reflectives reviews
An excellent radar with more range than Garmin - but is Wahoo's new Trackr radar better? | Cycling Weekly
So enamoured am I with this tech, I’ve even bought Garmin Varia RTL 515 radar units for my wife and two grown-up children. So, when Wahoo entered the radar market with its Trackr Radar in the spring, launched alongside the new Roam 3 and the Bolt 3, I simply had to take a look. Essentially, all bike radar systems emit a millimetre-wave radar signal from a small device mounted at the rear of the bike, which bounces off approaching vehicles behind the cyclist... Does Wahoo’s new radar unit comes close to matching the performance of Garmin’s venerable Varia units? I took it across France to find
Rating: 4.5 ​
REI Co-op
rei.com › cycling › bike accessories › bike lights › bike light sets
Wahoo Fitness TRACKR RADAR Cycling Radar and Taillight | REI Co-op
For the price should have a camera feature like the Garmin. Radar disconnects from my Hammerhead fairly often during ride. Had it on for a four ride and barely made it through. Those are the cons. It’s a nice bright light and when it works it’s outstanding. Its mount is really nice and I like it. I think a lot of the power drainage could be fixed with firmware updates. ... Great product! I have a few Wahoo products…
Bicycling
bicycling.com › bikes & gear › bikes & gear › i never ride without a radar light and wahoo’s trackr radar is my new go to
Wahoo’s Trackr Radar Tail Light Review
January 30, 2026 - The bad news is that Wahoo designed the Radar quarter-turn mount, which has the same orientation as Garmin’s Varia mount, to randomly be 1mm deeper. Just for fun? To be different? To get me to tear my hair out?
Bicycling
Wahoo's Trackr Radar Tail Light Review - Bicycling
Cyclingnews
cyclingnews.com › cycling tech & components
Wahoo Trackr Radar Review: Garmin's Varia has been dethroned | Cyclingnews
Brilliant battery life and excellent features make for a superb radar light
Rating: 4.6 ​
Competitive Cyclist
competitivecyclist.com › accessories › lights › tail lights
Wahoo Fitness TRACKR RADAR - Accessories
July 12, 2025 - Its compact, road-ready form includes a quick-connect strap and quarter-turn mount, making setup easy across multiple bike types. With an IPX7 waterproof rating and just 99 grams of weight, TRACKR RADAR offers a robust, intelligent rear visibility ...
Cyclists Hub
cyclistshub.com › home › bike radars › wahoo trackr radar review: a worthy varia competitor?
I tested the Wahoo TRACKR Radar: It's just as good as the Garmin Varia, and even better in these areas
April 15, 2026 - Below is the summary of the Wahoo TRACKR Radar technical specifications. ... Based on my testing, I found the following pros and cons of the TRACKR. ... The package includes three mount adapters (flat, aero, and d-shape) and also two rubber straps of different lengths. I use the aero adaptor with the shorter strap, and it works well with my seat post. ... I first tested the TRACKR with the Wahoo ELEMNT BOLT 3. I also paired my Garmin Varia RTL515 with a Garmin Edge 840 for side-by-side comparisons.
KOM Cycling
komcycling.com › blogs › news › kom-cycling-radar-mounts-are-now-compatible-with-the-new-wahoo-trackr-radar
KOM Cycling Radar Mounts Are Now Compatible with the New Wahoo Trackr Radar!
April 8, 2025 - Snap your Wahoo Trackr right onto your saddlebag with this secure and convenient clip. ... Our radar-ready saddlebags come with a built-in slot designed specifically to hold the radar in the optimal position.
reddit.com › r/cycling › garmin edge on wahoo mount
r/cycling on Reddit: Garmin Edge on Wahoo mount
September 3, 2021 -
Hi guys,
I know there is a puck adapter to mount a wahoo computer to a Garmin mount, but my question is vice-versa.
I was running a wahoo elemnt bolt for years but now my SO gifted me a Garmin edge 830 for my birthday.
Do I need an adapter to mount my new Garmin to my existing wahoo mount?
I didn’t find anything regarding that on the World Wide Web.
Thanks for your info!!
CycleChat
cyclechat.net › cycling forums › components, accessories & clothing
Getting creative with a Garmin Varia mount (pannier rack) & up front Wahoo mount? | CycleChat Cycling Forum
September 3, 2022 - Deal with the up front first as I think that'll be easiest. Wife not a confident cyclist. First time out in a long time for her today & she wanted to try out the Varia to see if it helped with her confidence. Issue was, my Wahoo wouldn't clamp on to her handlebar. The mount was supplied with 2...
KOM Cycling
komcycling.com › products › bike-rack-radar-mount
Bike Rear Rack Radar Mount – KOM Cycling
Replacement discs for Wahoo Trackr now available
Price   $24.99
Velo
velo.outsideonline.com › road › road gear › wahoo trackr radar review: strong on safety, but not enough to dethrone the years-old competition
Wahoo Trackr Radar Review: Is It Enough to Dethrone Garmin? - Velo
August 11, 2025 - (Photo Josh Ross/Velo) In terms of interface, Wahoo uses the same quarter-turn mount as its computers. Interestingly, that also has a benefit for the Wahoo Trackr radar mounting compatibility.
