Apple Community
discussions.apple.com › thread › 255882368
Samsung CLP-365W Drivers - Apple Community
Hi, I have a Macbook Air M2 and a Samsung CLP-365W printer, is it possible for me to connect it on Mac OS Sequoia? I have a bunch of failed attempts. https://support.hp.com/us-en/drivers/samsung-clp-365-color-laser-printer-series/17156870
HP
support.hp.com › us-en › drivers › selfservice › samsung-clp-365-color-laser-printer-series › 17156870 › model › 17156872
Samsung CLP-365W Color Laser Printer Software and Driver Downloads | HP® Customer Support
Download the latest drivers, firmware, and software for your Samsung CLP-365W Color Laser Printer.This is HP’s official website that will help automatically detect and download the correct drivers free of cost for your HP Computing and Printing products for Windows and Mac operating system.
I can't find driver for my Samsung printer that was functioning on Catalina
Anything here help? https://discussions.apple.com/thread/252034776 More on reddit.com
🌐 r/MacOS
5
4
December 3, 2020
HELP! Samsung CLP-365W printer and airprint | Synology Community
Hi! Come and join us at Synology Community. A place to answer all your Synology questions. Ask a question or start a discussion now. More on community.synology.com
🌐 community.synology.com
Samsung CLP-365W - Apple Community
Acourding to specks it no diferent to the one the specify. Where I live I can get the CLP-365W now and like to get it ASAP. But I have to beable to print from my 2 iMac's via wi-fi. I cant run a USB cable. ... http://www.samsung.com/africa_en/consumer/print-solutions/printers/colour-laser/ ... More on discussions.apple.com
🌐 discussions.apple.com
January 21, 2013
iMAC, Samsung, Drivers | MacRumors Forums
I am having communication issues between my iMAC (macOS Monterey v.12.1) and my Samsung printer. The generic driver provided by mac does not recognize that my printer can print in color, send a fax or scan a document. The printer is fresh out of the box, even though it is a 2012 model. I just... More on forums.macrumors.com
🌐 forums.macrumors.com
February 8, 2022
PrinterDrivers
printerdrivers.com › printer drivers › samsung › samsung clp-365 driver download
Samsung CLP-365 Driver and Software Download
February 5, 2026 - Download Samsung CLP-365 Driver and Printer Software for Windows 11, 10, 8.1, 8, 7, Vista, XP 32-bit and 64-bit, Mac and Linux OS.
Synology Community
community.synology.com › enu › forum › 17 › post › 63118
Here is a list of the Samsung drivers ... QL-6050...All of these printers are mono laser (ML = Mono Laser, QL = Quiklaser) so none of their drivers are suitable for your printer....
Apple Community
discussions.apple.com › thread › 4606912
January 21, 2013 - This printer Samsung CLP-365W is not specified on apples site as a AirPrint printer.
MacRumors
forums.macrumors.com › macs › macos › older macos versions › macos monterey (12)
February 8, 2022 - The only macOS thing downloadable from the HP site for that printer is a wireless setup app that is apparently 32bit and won't run in Monterey. Samsung/HP hasn't created a 64bit driver for it, apparently.
Apple Community
discussions.apple.com › thread › 4282113
Brand new Samsung CLP-365w wireless print… - Apple Community
January 21, 2013 - Just bought a new Samsung laser printer and it will not connect to mountain lion, apparently it only supports up to 10.7! Please, does anyone know of a patch for it to work with mountain lion? Really peeed off! ... 4. If you already have CLP-365w added, delete it by click on the printer, and ...
Samsungdrucker
samsungdrucker.com › en › samsung-clp-365w-color-laser-printer
Samsung CLP-365W Color Laser Printer Driver and Software
The Samsung CLP-365W’s print speed is rather slow for a laser, at 19 pages per minute (ppm) for black and white and 4 pages per minute for color.
Published   March 9, 2024
reddit.com › r/printers › getting the samsung clx-3185 and other old samsung printers to work with macos
r/printers on Reddit: Getting the Samsung CLX-3185 and other old Samsung printers to work with macOS
October 18, 2023 -
Hi :)
Just dumping my experience here as I dont know which place would be best for this, please point me to the right place if nescessary.
I just got a CLX-3185 with fresh toners for cheap, so I wanted to get it up and running with my M1 Mac Mini, which turned out to be more work than I expected. You will need the terminal for this.
0. Install Rosetta by typing softwareupdate --install-rosetta --agree-to-license in a terminal if you are on Apple Silicon and haven’t installed it yet
  1. Get the printer drivers from Apple by searching for them on the Apple support site, i.e. https://support.apple.com/kb/DL905 for the Samsung drivers.
  2. Open the downloaded .dmg file and open a terminal using Spotlight or /Applications/Utilities
  3. Enter mkdir drivers; cd drivers; xar -xvf,drag the .pkg in the .dmg into the terminal window and press enter. Enter open drivers to open the freshly created directory.
  4. Right-click the SamsungPrinterDrivers.pkg and click Open Package Contents
  5. Right click the file called Payload and open with archive utility; a Library folder should appear.
  6. Open your system drive in another Finder window and drag the Library folder from the other window to this one. You should be getting asked if you want to combine the Library folders.
  7. Try to add the printer normally, System Settings should detect it in the configuration dialog.
I'm on macOS 14 (Sonoma), it should work with older versions as well.
Background: The .pkg files available from Apple should do the job we are doing here manually, but they are too old to automatically work. Apple doesnt include these drivers anymore, as they are obsolete by Apples guidelines as well.
Again, please tell me if I should change something, I do not intend to infringe any guidelines.
I hope this helps someone :)
Edit: You may also have a look at u/Aldonio‘s comment for a bash script doing most of the work if you‘re comfortable with that :)
Dumping the printer names here so the search engines may point people needing this here:
C410 C460 CLP-300 CLP-310 CLP-320 CLP-350 CLP-360 CLP-410 CLP-610 CLP-620 CLP-660 CLP-670 CLP-680 CLP-770 CLP-775 CLX-216x CLX-3170 CLX-3180 CLX-3180 CLX-3300 CLX-4190 CLX-6200 CLX-6220 CLX-6240 CLX-6250 CLX-6260 CLX-8380 CLX-8385 CLX-8385X CLX-8540 CLX-8540X CLX-8640 CLX-9250 CLX-92x1 M2020 M2070 M262x M267x M332x M337x MFP ML-1630 ML-1630W ML-1640 ML-1660 ML-1860 ML-1865W ML-191x ML-2160 ML-2240 ML-2245 ML-2525W ML-2540 ML-2580 ML-2850 ML-2855 ML-2950 ML-331x ML-3470 ML-371x ML-4050 ML-451x ML-4550 ML-551x SCX-3200 SCX-3400 SCX-4300 SCX-4500 SCX-4500W SCX-4600 SCX-4623 SCX-4623FW SCX-4650 SCX-470x SCX-472x SCX-483x SCX-4x24 SCX-4x28 SCX-5635 SCX-5835_5935 SCX-5835_5935X SCX-6545X SCX-6x22 SCX-6x45 SCX-6x55 SCX-6x55X SCX-8030 SCX-8123 SF-76
VillMan Computers
villman.com › Product-Detail › Samsung_CLP-365W
Samsung CLP-365W Wi-Fi Colour Laser Printer | VillMan Computers
Product Description: ring photos on mobile devices to life with a Samsung Colour Laser Printer. You can print wirelessly in just three steps. It’s all delivered in amazing colour thanks to Samsung’s Rendering Engine for Clean Page (ReCP) and our new polymerised toner.
Apple Community
discussions.apple.com › thread › 255754214
Installing Samsung printer clp 620 nd on macOS Sonoma ...
Avoid anything HP makes; their Mac support has always been poor. ... Samsung no longer supports their printers. Support is now handled by HP. ... It appears the last driver update was 2017 and only mentions support for macOS 10.13 and earlier. macOS is now at 14.x.x with Sonoma with 15.x.x ...
TechSpot
techspot.com › drivers › driver › file › information › 17726
Samsung Universal Printer Driver for Mac 3.00 Download | TechSpot
January 16, 2015 - Download Samsung Universal Printer Driver for Mac 3.00. OS support: Mac OS X. Category: Printers
HP
support.hp.com › us-en › drivers › samsung-clp-365-color-laser-printer-series › 17156870
Samsung CLP-365 Color Laser Printer series
Download the latest drivers, software, firmware, and diagnostics for your HP products from the official HP Support website.
Samsung
samsung.com › us › support
Support Home | Official Samsung Support US |
Samsung Care is here to help. Samsung Support Home will help you find helpful content about popular topics and features, troubleshooting, and videos to help you do more with all your Samsung products from Galaxy Phones, TVs, Refrigerators, Washers & Dryers, and everything else in between.
Amazon
amazon.com › Samsung-Electronics-CLP-365W-Wireless-Printer › dp › B008HSIVVC
Amazon.com: SAMSUNG Electronics CLP-365W Wireless Color Printer : Office Products
Canon Color imageCLASS LBP646Cdw Wireless Laser Printer for Duplex Printing, White - 26 PPM Home Office, Small Office Printer ... Brief content visible, double tap to read full content. Full content visible, double tap to read brief content. Help others learn more about this product by uploading a video!Upload your video ... The Samsung CLP-365W features Samsung's latest image processing and polymerized toner formulation, for exceptionally vivid color and razor-sharp text and graphics.
