I installed LM because its the most simple and "just works" distro but for the life of me I cant find the setting to adjust the mouse scroll speed? My laptop touch pad if i just barely two finger scroll it moves the whole page. Surely such a simple feature exists...right? Well I googled it and found a dozen or so answers, all completely different, all involving random commands or terminal tweaks...Is there no simple way to do this still!?
Faster Mouse Scrolling -Solved
Linux Mint mouse wheel scroll speed - Linux - Level1Techs Forums
Scrolling Speed | Vivaldi Forum
How do you change the scroll speed
Videos
There wasn't a lot of updated info on this so I gathered a bit did some testing and have some easy clear instructions.
Basically out of the box mouse scrolling is pretty slow. In others you can just select from a list and click more lines for faster. Not here with Mint. Especially for new users it's confusing. So this isn't an exact step by step but you should get enough to work through it.
For Logitech Mice check Solaar, not scrolling but does have custom options key remapping etc. I swap side buttons 4, 5. So the Back is the forward most button right at my thumb tip since it's most common/frequent. Then the forward have to bend back a bit more
Tips
To check mouse button identification for customization etc
--From Terminal use xev | grep button
--Ctrl-C to exit it
For Linux Mint 21.1 + and probably many more
Install Imwheel pkg from package manager or terminal etc
Go to Home folder(should also see Pictures and Music) and create New File then save as .imwheelrc
Copy and past this for ALL (change the 4 at end for speed--- + for faster or - for slower) 3-5 is pretty common
None, Up, Button4, 4
None, Down, Button5, 4
Control_L, Up, Control_L|Button4
Control_L, Down, Control_L|Button5
Shift_L, Up, Shift_L|Button4
Shift_L, Down, Shift_L|Button5
=========For app specific add this modifying the 4 at end up or down for each app as needed
"^firefox$"
Shift_L, Up, Shift_L|Button4, 4
Shift_L, Down, Shift_L|Button5, 4
"^chromium$"
3. Then save
Use Terminal "killall imwheel" to stop any current process then to start with changes
run in Terminal and type: imwheel
BUT
Then imwheel disables back/forward side buttons so need to isolate imwheel to only apply to the up/down so use this to start it. Modifications need it to be stopped and restarted or logout
--imwheel -b "4 5"
4. To make it start at boot in Mint go to menu then search for Startup Apps click plus at bottom
In the popup type an app name and in the command box put: imwheel -b "4 5"
Then description like Faster scrolling or something, save and logout/reboot to verify
You should now have auto start faster scrolling with working back/forward buttons. Along with cranking up the mouse pointer speed to almost fastest it's much easier to use now.
Another slightly easier and less text file changing is
Install Mousewheel
Mouse Wheel GUI scroll app which uses Imwheel and does all of the above https://github.com/kelebek333/mousewheel sudo add-apt-repository ppa:kelebek333/tools sudo apt update sudo apt install mousewheel Uses IMWheel so likely need to add line at startup apps -imwheel -b "4 5" as described below otherwise it kills side back/forward buttons. You now have a mousewheel app in menu If it works and you don't need mouse side buttons then great For working side buttions go to Startup Apps Find imwheel in list click on it to highlight then click on pencil icon in bottom of window. In the command box add so it says imwheel -b "4 5" Save and close, you'll wanna logout and in to make sure it takes effect. Now you get side buttons back
