Google Patents
patents.google.com › patent › WO2023028355A1 › en
WO2023028355A1 - Implantable biosensor and communication node with plasmonic nano-antenna - Google Patents
Fig. l is a schematic block diagram illustrating an embodiment biosensor with a plasmonic nano-antenna that is configured both to sense presence of a biomarker and to send a communication to a physically separate communication node using the same light emitted from the plasmonic nano-antenna.
NSF PAGES
par.nsf.gov › servlets › purl › 10341666 pdf
Joint Communication and Bio-sensing with Plasmonic ...
human tissue channel model for optical signals, plasmonic · biosensors, biofunctionalization and joint communication and · sensing. In Sec. III, we present the design of an optical · nanoantenna. In Sec. IV, we evaluate the performance of the · nano-patch antenna as a biosensor.
arXiv
arxiv.org › html › 2401.07252v1
Nanoantennas and Nanoradars: The Future of Integrated Sensing and Communication at the Nanoscale
January 14, 2024 - One such instance emphasizes on the employement of dielectric dot radiators, represented by the optical dot antenna (ODA), as a flexible way for arranging electromagnetic properties, thereby supporting transmission and directivity within bull’s eye structures applicable to biosensors and nanophotonics [231]. Equally notable is the integration of plasmonic nanoantennas, manufactured by the indium-tin oxide (ITO) nanorod arrays, which, as an alternative to conventional plasmonic materials like gold and silver, avoid their inherent limitations—such as high loss and cost [234]. These examples are only a few out of many in the literature.
reddit.com › r/transhumanism › intra-body molecular communication via blood- tissue barrier for internet of bio-nano things (iobnt)
r/transhumanism on Reddit: Intra-Body Molecular Communication via Blood- Tissue Barrier for Internet of Bio-Nano Things (IOBNT)
November 17, 2024 -
In the Intra-body nano networks, the bio-nanomachines enter the body through injection into the blood and then navigate autonomously throughout the body to reach the blood capillary network. The blood tissue barrier inside the body forms the main communication pathway for molecular information exchange between the nanomachines as well as between the intra-body nano network and the Bio-Cyber interface in the IoBNT network. Watch the video to learn more about how the Brain Tissue Barrier, the Blood Brain barrier, the Intra-body nanonetwork, and The Bio-Cyber interface all work together in this research in mimicking biology for nano communication.
https://opus.lib.uts.edu.au/handle/10453/159605
Top answer 1 of 5
6
YES I did use chatGPT to parse the paper: It's 100% simulation and modeling—no wet lab, no hardware, no live implants. Just molecules in silico. Here's what they did do: Built a COMSOL Multiphysics numerical model of molecule transport across capillary walls. Developed a custom MATLAB particle simulator to validate the model—tracks molecule-by-molecule movement under diffusion, flow, degradation, and capillary permeability. Compared the two to ensure the math holds up. Ran a bunch of simulations changing parameters (flow speed, distance, emission duration, permeability, etc.) to see how they affect the molecular "signal" received. What they did not do: No experiments with nanorobots or nanomachines. No animal or human testing. No physical bio-cyber interface prototypes. No integration with actual sensors or drug delivery systems.It's 100% simulation and modeling—no wet lab, no hardware, no live implants. Just molecules in silico. It's a toolbox contribution: if someone were building a real nano-drug-delivery system, this could guide where to place the transmitter, how fast to release the drug, how to interpret signals, or even how to design the capillary interface. Conclusion: Its a modeling tool, nothing more.
2 of 5
3
Video credit to ByrdTurd86. Hoping to share more research papers and “cutting edge,” or lesser known, developments. Hopefully this is okay with mods of this subreddit! Thank you in advance. CRISPR-Enabled Graphene-Based Bio-Cyber Interface Model for In Vivo Monitoring of Non-Invasive Therapeutic Processes
ScienceDirect
sciencedirect.com › science › article › abs › pii › S1878778921000247
Beamforming optical antenna arrays for nano-bio sensing and actuation applications - ScienceDirect
May 21, 2021 - Despite the small wavelength, current technologies used in these fields are not nanoscale and, in many occasions, not wireless, thus limiting the potential applications. For example, the majority of groups currently working on state of the art plasmonic nano-sensors use bulky equipment setups to read the data from sensors in ex-vivo measurements (e.g., in blood samples [1]).
arXiv
arxiv.org › html › 2405.07812v1
Electromagnetic Nanonetworks Beyond 6G: From Wearable and Implantable Networks to On-chip and Quantum Communication
May 14, 2024 - The latter aspects are of fundamental relevance for a nanonetworking paradigm where biomedical applications were paramount [7]. On the other hand, electromagnetic communications in the nanoscale were studied given their higher capacity and wider applicability, also spurred in part by the advancement in miniaturized plasmonic antennas in the terahertz and optical ranges [8]. Hence, the concept of electromagnetic nanonetworks (the main focus of this manuscript) was born.
Aims Press
aimspress.com › article › doi › 10.3934 › bioeng.2023019
Nanoscale antenna systems: Transforming wireless communications and biomedical applications
In the biomedical field, antennas integrated into implantable medical devices and biosensing platforms are explored. The article examines the use and fabrication of biocompatible materials for biomedical antennas by considering their applicability in biomedical environments. Performance analysis and characterization techniques for nanoscale antennas are presented, including calibration methods, radiation sample analysis, gain, efficiency, impedance matching and analysis of performance parameters in various typical application scenarios.
PubMed Central
pmc.ncbi.nlm.nih.gov › articles › PMC4431286
Optical Nano Antennas: State of the Art, Scope and Challenges as a Biosensor Along with Human Exposure to Nano-Toxicology - PMC
LSPR biosensors are based on localized surface plasmon (LSP) phenomena [85,86]. At the plasmon resonant frequency, the optical extinction of a nanoparticle become maximum, which is dependent on the adjacent medium’s refractive index and the nanoparticle’s size and shape.
PubMed Central
pmc.ncbi.nlm.nih.gov › articles › PMC9611134
Materials Perspectives of Integrated Plasmonic Biosensors - PMC
An important area that can benefit from the advances of plasmonic doped semiconductors is surface-enhanced Raman spectroscopy (SERS), which is a technique that spectrally analyzes the chemical and biological properties of analytes via deep interactions at the plasmonic surface level [130]. In [127], the authors demonstrate the use of an InAsSb antenna array deposited on gallium antimonide (GaSb) for SERS of vanillin (Figure 5b). The field enhancement concentrated around the corners of the nanoantennas is used as the main property for sensing.
ACM Digital Library
dl.acm.org › doi › 10.4108 › eai.28-9-2015.2261410
Metallic plasmonic nano-antenna for wireless optical communication in intra-body nanonetworks | Proceedings of the 10th EAI International Conference on Body Area Networks
Nanonetworks are the enabling technology for unique applications, including intra-body health-monitoring and drug delivery systems. In this paper, metallic plasmonic nanoantennas for wireless optical communication in intra-body nanonetworks are modeled and analyzed.
PubMed Central
pmc.ncbi.nlm.nih.gov › articles › PMC12195759
Graphene-Based Plasmonic Antenna for Advancing Nano-Scale Sensors - PMC
Plasmonic nanostructures can improve the optical properties of graphene, whereas graphene can modulate the optical response of plasmonic nanoarrays, creating a synergistic effect for sensing applications. Consequently, noble metal superstructure surfaces combined with graphene can be utilized to control light waves accurately and effectively [22]. This capability enables Graphene’s application in fields such as bioimaging [23], drug delivery [24], and biosensors [25].
MDPI
mdpi.com › 2227-9040 › 10 › 5 › 150
Plasmonic Nanosensors: Design, Fabrication, and Applications in Biomedicine
April 20, 2022 - In this review, we summarize the most recent plasmonic nanobiosensors proposed for applications in biomedicine by considering the main fabrication techniques related to colloids, arrays, and flexible plasmonic substrates. Particular attention is given to their application in both inherent resonance-based biosensors and signal amplification-based biosensors.
