Gunvor Group
gunvorgroup.com › home › vacuum gas oil
Vacuum Gas Oil - Gunvor Group
February 25, 2025 - **Vacuum Gas Oil (VGO)** Vacuum Gas Oil, often abbreviated as VGO, refers to a group of intermediate oil products obtained during the petroleum refining process. VGO is produced in a vacuum distillation unit, which operates at a pressure well below atmospheric pressure, allowing the oil to ...
Honeywell
uop.honeywell.com › en › industry-solutions › refining › vacuum-gas-oil-conversion
Vacuum Gas Oil Conversion
Vacuum gas oil (VGO) is a key feedstock for fluid catalytic crackers used to make transportation fuels and many other by-products.
Fortune Business Insights
fortunebusinessinsights.com › home › energy & power › vacuum gas oil market
Vacuum Gas Oil Market Size, Industry Share | Forecast [2025-2032]
Vacuum gas oil is also referred to as cat feed because it is utilized as a feedstock to create gasoil, gasoline, and other by-products. On the basis of the product, the vacuum gas oil market can be segmented into Light Vacuum Gas Oil (LVGO) ...
Evonik
evonik.com › home › applications › vacuum gas oils
Vacuum Gas Oils
Vacuum Gas Oil (VGO) is one of the two outputs of the vacuum distillation tower (along with vacuum resid). VGO is the lighter material of the two. The primary use of VGO is as feed to cracking units such as the FCC or the hydrocracker. These units upgrade VGO into more valuable products, namely ...
en.wikipedia.org › wiki › VGO
VGO - Wikipedia
September 1, 2023 - Vacuum gas oil, heavy oils left over from petroleum distillation that can be further refined in a catalytic cracking unit ... A series of very large bomber aircraft produced by Gothaer Waggonfabrik; see Zeppelin-Staaken V.G.O.I
Energy Tracker
energytracker.asia › energy tracker asia › fossil fuel › could the rise of vacuum gas oil (vgo) signal the fall of oil?
Could the Rise of Vacuum Gas Oil (VGO) Signal the Fall of Oil?
June 2, 2024 - Vacuum Gas Oil (VGO) is a versatile product derived from the refining process, finding extensive applications in various industries. One of the key uses of VGO is as a feedstock in catalytic cracking units to produce lighter fuels such as gasoline ...
RBN Energy
rbnenergy.com › daily energy posts › blog
Going to a VGO? – The Intermediate Feedstock You Wish You Knew!
August 22, 2014 - Vacuum distillation breaks out light and heavy gas oil fractions leaving vacuum residuum that can be further processed by a coker unit or sold as fuel oil (see Yo-Ho-Ho and a Cargo of Bunkers for more on fuel oil).
Psu
courses.ems.psu.edu › fsc432 › content › conversion-and-processing-vacuum-gas-oils
Conversion and Processing of Vacuum Gas Oils | FSC 432: Petroleum Refining
HVGO can also be used as a feedstock to produce lubricating oil base stock, through a sequence of solvent extraction processes to remove aromatic hydrocarbons by furfural extraction, and to remove long-chain paraffins by dewaxing (Figure 3.8). Figure 3.7. Hydrocracking of light vacuum gas oil.
Mckinseyenergyinsights
mckinseyenergyinsights.com › resources › refinery-reference-desk › vgo
VGO | McKinsey Energy Insights
VGO is one of the two outputs of the vacuum distillation tower (along with vacuum resid). VGO is the lighter material of the two. The primary use of VGO is as feed to cracking units such as the FCC or the hydrocracker. These units upgrade VGO into more valuable products, namely gasoline and diesel. If not upgraded, VGO is blended into residual fuel oil.
European Chemicals Agency
echa.europa.eu › substance-information › - › substanceinfo › 100.059.126
Substance Information - ECHA
Gas oils (petroleum), heavy vacuum; Heavy Fuel oil [A complex combination of hydrocarbons produced by the vacuum distillation of the residuum from atmospheric distillation of crude oil.
Apexoil
apexoil.com › wp-content › uploads › 2016 › 02 › msds-vacuumgasoil.pdf pdf
Vacuum Gas Oil Safety Data Sheet
: Vacuum Gas Oil · Product form · : Mixture · Formula · : Petroleum Hydrocarbon, a complex combination of hydrocarbons having carbon numbers · predominately higher than C20, and may contain hydrogen sulfide. Other means of identification · : Atmospheric Gas Oil, Straight Run Fuel Oil, ...
Precisionbusinessinsights
precisionbusinessinsights.com › market-reports › vacuum-gas-oil-market
Vacuum Gas Oil Market Size, Price, Forecast To 2031
The VGO or vacuum gas oil fits the petroleum hydrocarbon, a part of the heavy distillate family. Vacuum gas oil is also called cat feed because it is used as a feedstock to generate gasoline, gasoil, and other by-products.
Expert Market Research
expertmarketresearch.com › home › energy and power › oil, gas, and fuel › vacuum gas oil market
Vacuum Gas Oil Market Size, Share & Growth Rate, 2034
As an important feedstock in sophisticated refining operations, vacuum gas oil is a vital component in the production of gasoline and diesel. The growing demand for fuel and petrochemical products also fuels market growth. Stringent environmental regulations, however, are compelling refiners to use cleaner technologies, affecting supply dynamics.
IMARC
imarcgroup.com › vacuum-gas-oil-market
Vacuum Gas Oil Market Share, Price Trends | Forecast 2033
Low sulfur vacuum gas oil (VGO) is a critical segment in the refining industry, characterized by a reduced sulfur content, typically meeting or exceeding stringent environmental regulations.
The Business Research Company
thebusinessresearchcompany.com › report › vacuum-gas-oil-global-market-report
Vacuum Gas Oil Market Growth, Size And Forecast Report By 2034
Global Vacuum Gas Oil market size is expected to reach $582.57 billion by 2029 at 6%, fossil fuel demand boosting vacuum gas oil market growth
Market Research Future
marketresearchfuture.com › home › reports › energy & power › vacuum gas oil market research report—global forecast till 2032
Vacuum Gas Oil Market Size, Share, Growth Report, 2035
October 11, 2025 - This growth trajectory reflects a compound annual growth rate (CAGR) of 5.19% from 2025 to 2035. Such projections underscore the increasing reliance on vacuum gas oil as a critical feedstock in various refining processes, driven by the rising demand for high-quality fuels and petrochemicals.
