reddit.com › r/linuxquestions › make betterbird use the thunderbird profile
r/linuxquestions on Reddit: Make Betterbird use the Thunderbird profile
July 25, 2025 -
I would like to try Betterbird. The Betterbird website says that it is very easy to test, as Betterbird can directly use (not import) the Thunderbird profile. "You can install Betterbird at the same time as Thunderbird and run them on the same profile."
Unfortunately, I can't make it work.
I run Tuxedo Linux and have Thunderbird installed as a deb-package (not Flatpack). On the Betterbird Website I can download a linux archive and directly start betterbird (I just doubleclick on the betterbird.bin file in the folder I unpacked the archive in). Or I can install it as a flatpack using discover. In both cases Betterbird asks me to setup my e-mail account and does not find / use / recognize an existing Thunderbird profile.
The Betterbird support page (https://www.betterbird.eu/support/#switch-tb-bb) mentions something how to switch between the two but I don't know what to do here.
Does anybody have experience how to make Betterbird use my existing Thunderbird profile. I assume that I somehow have to tell Betterbird where to find my Thunderbird profile. However, I don't know how and I don't even know where my Thunderbird profile is stored...
I'd appreciate any advice. Thanks.
Top answer
1 of 2
3
The documentation provided gives pretty clear information about how to solve this. I've never used this so I'll have to ask you a few questions: How Thunderbird and Betterbird installed? is it a .deb or flatpak installation? Was everything (Thunderbird and Betterbird) installed using default settings?
2 of 2
2
Have you used the terminal before? In it you can run the Flatpak version (which I would recommend) like this: flatpak run eu.betterbird.Betterbird -p Then, following the support page you linked, you should create a profile and do the minimal amount of setup to close the profile manager. For the copy: You should be able to open both ~/.thunderbird (for your deb-Thunderbird) and ~/.var/app/eu.betterbird.Betterbird/.thunderbird in the URL bar of your file manager. The terminal also works if you're familiar with cd, ls, cp, etc. Thunderbird profiles are named with a bunch of random letters, so you'll need to figure out on your own which directory is your real one. You can look at the "Last Changed" timestamp or the contents of profiles.ini if you're not sure. As an example mine is named like this: tzevfn17.default Again following the support page, you'll want to delete the contents of the newly created profile in the Betterbird directory, and copy the contents of your old profile into it. Double check which one is which so you don't accidentally delete your old profile. After that you should be able to start the Flatpak Betterbird from the application launcher and it should "just work". The one you got from the .tar.bz2 won't work from this, I'm not sure how that one handles profiles.
reddit.com › r/betterbird › need help: migrating email filters & settings from thunderbird to betterbird
r/Betterbird on Reddit: Need Help: Migrating Email Filters & Settings from Thunderbird to Betterbird
January 24, 2024 -
SEE UPDATE BELOW - STILL NOT WORKING
After learning about Betterbird's superior features, I was eager to test it out. To my surprise, the transition from Thunderbird required manual transfer of settings, which was unexpected since I didn't find an automatic import option for my email accounts. Dealing with five separate email accounts for my businesses, I assumed that email filters would automatically carry over.
Unfortunately, despite manually moving my settings, the email filters didn't follow suit, and I haven't found any guidance on whether this is feasible. Given that Thunderbird and Betterbird are built on the same foundation, it baffles me that there isn't a simple import function for all existing settings and filters from an updated Thunderbird installation.
Without this capability, I'm at a crossroads. Thunderbird's bugs are manageable, but the absence of an easy import for my extensive list of filters is a significant obstacle. I am reaching out for any help or insights that could facilitate this transition. The move to Betterbird interests me, but it hinges on the platform's ability to fully integrate my existing settings, filters, and more.
P.S. I’ve also noticed that my email signatures haven't transferred over. While this might be a minor issue compared to the others, it adds to my hesitation. The prospect of switching is becoming increasingly unattractive without these core functionalities.
UPDATE:
  1. I'm running the TB Beta and I have several TB profiles when I go to IMPORT
  2. When I first posted this, I imported the incorrect profile and that would explain no FILTERS importing I guess but as soon as I setup an account, I begin building filters SO....I guess maybe it doesn't make sense.
  3. In any case, I switched to the "default-beta" profile found at: C:\Users\me\AppData\Roaming\Thunderbird\Profiles\v23vn66u. default-beta
    1. Did the import again and this time, it did ask me for password for the accounts that weren't Gmail but FILTERS HAVE NOT IMPORTED???
    2. As a last ditch attempt to get this working, I uninstalled and reinstalled and I've gone through the IMPORT AGAIN......and still....NO FILTERS????
I really do want to give Betterbird a FAIR chance but I need these issues fixed or a resolution found before I can make a switch. ANY HELP WOULD BE GREAT!!!
Regards,
David
Betterbird
betterbird.eu › support
Betterbird: Support
If Betterbird doesn't already detect your Thunderbird profile, start Betterbird with the -p option (here shown for Windows), which will launch the profile manager. You can select your regular profile there. Another option is to view all profiles via Help > Troubleshooting Information.
reddit.com › r/thunderbird › how does tb determine which profile to use when opened?
r/Thunderbird on Reddit: How does TB determine which profile to use when opened?
August 16, 2024 -
When I open TB (actually Betterbird, on Windows) by double-clicking from my desktop, my profile opens just fine. But when I try to open a .ics file by double-clicking, I get an error "Your Betterbird profile cannot be loaded. It may be missing or inaccessible." I get the same thing if I use "open with..." and choose the exact same .exe file that the BB shortcut points to. So how does the app decide what profile it should be using?
I expect this is related to the problem I posted about a week ago, where every time I install an update, it creates a new profile for me, so I have to manually empty out that new profile and move all my data out of the previous profile and into the new one.
Top answer
1 of 2
2
I think I've solved the problem. It seems to come from the fact that I'm using Betterbird, and that this doesn't have a profile of its own, but hijacks the profile from Thunderbird. I still don't understand why new installs don't honor this properly, but it does explain why my attempt to fix the problem by uninstall and then re-install (even using Revo for the uninstall) didn't work. What I wound up doing was to Close BB and then move the contents of my active profile to another directory Uninstall BB Delete the whole TB profiles repository in C:\Users\username\AppData\Roaming\Thunderbird\Profiles Re-install Betterbird by way of chocolatey (choco install betterbird) Run BB to get it to set up a new profile of its own (cancelling out without bothering to enter all the mailbox settings) Find the new profile directory Close BB Move the original profile contents that you'd set aside elsewhere into the new default profile Everything seems fine now, and I'm hopeful that by putting this under chocolatey control, rather than a manual install process, that I'll avoid the problem in the future.
2 of 2
2
I'm a long time satisfied Thunderbird user. But early on, I always found myself at odds with its Profile Manager. It would often do unexpected things, creating new profiles when I didn't want or need one, or TB getting itself out of whack with my existing profile location after maintenance. I was frustrated as hell with the whole profile manager experience and was constantly doing battle with it until I hard-coded the location of my permanent profile into TB's startup parameters using the profile parameter. For me, this totally bypassed the profile manager and its shenanigans - and tells TB exactly where to find the profile I want it to use at startup, which by the way, is on my NAS and never moves. TB's Profile Manager's functionality and logic may have value for users with complex needs and multiple profiles. But the vast majority of users like me only use one profile. Consequently, the over-zealous profile manager, with its penchant for making new profiles, becomes a pain in the ass. OP's compliant is a perfect example.
reddit.com › r/betterbird › betterbird (linux) and the .thunderbird folder?
r/Betterbird on Reddit: Betterbird (Linux) and the .thunderbird folder?
October 14, 2024 -
I have been using and LIKING Betterbird for the best part of this year and would like to rid my machine of all things "Thunderbird"--however I find that BB uses the .thunderbird configuration folder.
I tried copying the contents of same to a .betterbird folder, and re-configured the Account Settings Local Folder to my new folder--that worked, but I found on restart BB recreated the ,thunderbird folder and repopulated it with a few files.
Deleting that caused BB to behave as if it were a new install?
I restored the .thunderbird folder from the backup I made before mucking about, and re-configured the BB Local Folder setting, and all is well. however my question is does BB need to have that .thunderbird folder to run properly?
Can I change that behaviour?
Linux Mint Forums
forums.linuxmint.com › board index › main edition support › software & applications
BetterBird and Thunderbird - Linux Mint Forums
But in the meantime, you could confirm that newly downloaded e-mails are or are not saved in the TB file location, which for me is /home/mike/.thunderbird/ithagkqh.default2/Mail/mail.mflan-1.com/Inbox. If it is stored in there then you already have the dual access capability you are asking for.
reddit.com › r/betterbird › having no luck migrating from thunderbird to betterbird - please help
r/Betterbird on Reddit: Having no luck migrating from Thunderbird to Betterbird - please help
June 20, 2025 -
So, per the heading, I;ve been using Thunderbird for a while now, and I'd like to try Betterbird to see if it is genuinely better. I'm a FOMO person - forgive me.
Thunderbird is installed and working pretty well, even with MS Exchange servers (using OWL) which is a big plus for me.
The instructions seem to indicate that I can simply install Betterbird (which I have done using the Flatpak version) and then copy my Thunderbird config to replace the Betterbird config.
I found both configs under ~/.var/app so I renamed the new (untouched) Betterbird config and replaced it with my old Thunderbird config, using the commands below:
cd ~/.var/app
mv eu.betterbird.Betterbird/ eu.betterbird.Betterbird-new
cp -r net.thunderbird.Thunderbird/ eu.betterbird.Betterbird
Yet when I start Betterbird it acts as if it was a new installation, asking me to configure the first e-mail address.
I'm sure I'm doing something dumb, but what is it?
EDIT: I've just found a Betterbird directory at:
/var/lib/flatpak/app/eu.betterbird.Betterbird/x86_64/stable/93b6ddc26f7b6f2371c6be1b04855f183d912554a613b8ef7a7f02ca45668122/files/lib/betterbird
Which is probably the one I want to patch (since it's presumably the Flatpak instance). Trouble is, there doesn't seem to be config dir, anywhere in the vicinity.
GitHub
github.com › flathub › eu.betterbird.Betterbird
GitHub - flathub/eu.betterbird.Betterbird · GitHub
Caveats: Once Betterbird has access to your home directory, it will use the profile in ~/.thunderbird instead of ~/.var/app/eu.betterbird.Betterbird/.thunderbird. Meaning that in order to keep using your current profile, you will have to move it to ~/.thunderbird after applying the work-around.
Betterbird Blog
blog.betterbird.eu › 2025 › 12 › mozilla-profiles
Mozilla Profiles - Betterbird Blog
December 7, 2025 - The next thing you need to understand that Firefox/Thunderbird 68 introduced the principle of "Profile per installation", that means if you install the software into a different location, it will no recognise a previously used profile, but you ...
reddit.com › r/thunderbird › thunderbird and betterbird not working
r/Thunderbird on Reddit: Thunderbird and Betterbird not working
August 31, 2024 -
i started getting this 'Your gmail settings are out of date' message but i could not figure out what settings they were talking about or the way to fix them. and Thunderbird just kind of ground to a halt. tried Betterbird and its the same story.
what do i do and how do i do it? i have 7 active emails and it's killing me.
thanks to all in this community, you guys are great.
reddit.com › r/betterbird › filters from thunderbird to betterbird
r/Betterbird on Reddit: Filters from Thunderbird to Betterbird
May 1, 2026 -
I just switched to Betterbird from Thunderbird and and EXTREMELY SATISFIED!! Everything seemed to come in great since I have an IMAP with Google account. But I noticed my Thunderbird Message filters did not transfer over, understandably. I am not sure if I want to import those filters since I had Thunderbird for probably 15 years, and there are a TON of filters. I see in Thunderbird there are also numerous profiles, each having their own message filters. If I decided to copy the message filter data over to BetterBird, should I combine all my data from 3 different profiles into one data file? And I am assuming I would just put my 'msgFilterRules.dat' file into my new Betterbird profile, correct?
Top answer
1 of 2
1
Yes, filters are stored in msgFilterRules.dat in the respective account. If you know what you're doing, you can edit those files manually, but if your make a mistake, the next program start may obliterate it.
2 of 2
1
Normally, when you switch from Thunderbird to Betterbird (i.e. you use Betterbird for the first time), Betterbird uses your current (latest) Thunderbird profile. As such, you get all your emails, all your local folders... and all your filters. It also means that, when you open Betterbird, you should not have Thunderbird open at the same time. I also suspect that if you had the extension FiltaQuilla in Thunderbird (it adds a few filtering options), you might have problem filtering until FiltaQuilla is installed in Thunderbird. Another issue you might have with filters is that, if your first use of Betterbird took too long to connect, filters might simply be de-activated because the folders you are sending the mails to were not yet active at that time. So check within your filter rules whether you have a lot of deactivated filters and reactivate them. (I once had to redefine one destination folder because, for some obscure reason, it didn't recognize the path it was using the day before – some changes server side). Importing Filters I don't think you can combine filters from multiple places, but you can transfer ONE 'msgFilterRules.dat' file from one place to the other. First, check what is your latest profile in Thunderbird and in Betterbird. Take note of it. Assuming you are using IMAP, your filters will be attached to each account, like this: C:\Users\user_name\AppData\Roaming\Thunderbird\Profiles \whatever_name.default\IMAP\account_1 (The "whatever_name.default" probably has today's date, and is used both by your latest Thunderbird and Betterbird incarnations.) There is one 'msgFilterRules.dat' file per account. I don't know whether or not using "Unified folders" changes that because I never used Unified folders. Sizewise, my main account has 20 rules and its 'msgFilterRules.dat' file is 7k. All my other accounts have only one or two rules and the file is only 1k. It is safe to copy the 'msgFilterRules.dat' file from one place to another when Betterbird (and Thunderbird) are closed.
Betterbird Blog
blog.betterbird.eu › category › support
Support - Betterbird Blog
August 20, 2026 - The next thing you need to understand that Firefox/Thunderbird 68 introduced the principle of "Profile per installation", that means if you install the software into a different location, it will no recognise a previously used profile, but you ...
Linux Mint Forums
betterbird remembers old mail settings on new machine - Linux Mint Forums
What happened was not due to Linux Mint, but to the servers you used. Betterbird, like Thunderbird, searches for possible combinations of working mail servers and extracted illegally stored data from your old email server.
Top answer
1 of 1
1
Dear Donald Bock,
Thanks for reaching out to the Microsoft Q&A community. I understand you're using Betterbird on Windows 10 Pro to access your Outlook.com emails and are running into trouble with the setup and profile migration. I'm happy to help you get this sorted out.
1, Outlook.com Configuration for Betterbird
To make sure Betterbird is configured correctly to download your emails from Outlook.com, please check the settings below. We usually recommend using IMAP, as it syncs your emails across all your devices.
  • Incoming Mail (IMAP)
    • Server: imap-mail.outlook.com
    • Port: 993
    • Security: SSL/TLS
    • Authentication: Normal password
  • Outgoing Mail (SMTP)
    • Server: smtp-mail.outlook.com
    • Port: 587
    • Security: STARTTLS
If you have two-factor authentication (2FA) enabled on your Microsoft account, you'll need to generate and use an app password instead of your regular password.
For more details on how to manually configure email accounts in Classic Outlook for Windows, please refer to this official Microsoft article: Add an email account to Outlook for Windows
2, Betterbird Profile Migration and Features
You mentioned having issues with your profile and with dragging and dropping folders. While we have limited ability to troubleshoot third-party applications like Betterbird, here's some general guidance that may help.
For issues with profile migration, such as copied data not appearing, it's often caused by incorrect folder structure or corrupted data. Betterbird's support resources or community forums are your best bet for detailed steps on resolving these specific problems. Similarly, the drag-and-drop feature you're looking for is not supported, and you would need to use a specific add-on for that functionality.
Please let me know if you need help with the Outlook.com configuration settings or if you have any other updates. We're here to help!
3, References
For your reference, here are a couple of articles that provide more details on email configuration:
  1. Server settings you'll need from your email provider - Microsoft Support
  2. Change or update email account settings in Outlook for Windows - Microsoft Support
  3. POP, IMAP, and SMTP settings for Outlook.com - Microsoft Support
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
Linux.org
linux.org › home › forums › general linux forums › general computing
Get folders into Betterbird from Thunderbird | Linux.org
December 17, 2023 - Click to expand... The main issue the program was having was that it somehow was looking for the wrong Thunderbird folder to import from. After digging around some more, I found the Thunderbird and Betterbird folders that were not being removed when the programs were uninstalled.
reddit.com › r/betterbird › betterbird won't open tb profile
r/Betterbird on Reddit: Betterbird won't open TB profile
November 6, 2024 -
I installed Betterbird, and made a copy of my Thunderbird profile so I could test it without mucking up Thunderbird.
When I try to open the copy of the profile, I get this message:
A newer version of Betterbird may have made changes to your profile which are no longer compatible with this older version. Use this profile only with that newer version, or create a new profile for this installation of Betterbird. Creating a new profile requires setting up your accounts, calendars and add-ons again.
I looked and am running a newer version of TB, than BB. TB...128.4.1esr, BB...115.17.0-bb35
What can I try at this point?
Do I have to just stop updating TB and wait until BB gets caught up?
Linux Mint Forums
Thunderbird to Betterbird Migration - Linux Mint Forums
April 5, 2023 - However, when I start up Betterbird, it wants wants me to setup an account. It doesn't recognize the .thunderbird file I transferred from my old computer into the location (and added "_legacy" to the name of its original .thunderbird file. Do I just set up and account and everything will work fantastic?
